Reply
Downstream low Nighthawk CAX80
Anayancydt
Follower
Our new modem was supposed to be better then our last but it still has moments where the internet just shuts down. I did notice our downstream is low. Also I must note I did put an amplifier on the cable line in order to increase signal.
Message 1 of 3
Re: Downstream low Nighthawk CAX80
What do you experience when this happens? Dead wifi? Lost wired connections?
What do the LEDs on the thing indicate?
Your downstream what is low?
If you have problems on your line, you should take that up with the ISP.
It is not a good idea to try to fix the ISP's problems by adding an amplifier, or anything else, to the network. You should get a good connection with nothing between the modem/router and the socket in the wall.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Guru
You didn't get much info off there (screen snip the whole thing) but if you're running an amplifier, remove it. You're power level on the downstream is at 18dbi. Way Way to high.
Take that off and then connect it back up and get a screen snip of the whole cable connections page (upstream/downstream and values) and the event logs and post them back here. Clear out the logs and use it for a bit and then get those. Otherwise its going to have the data from when you were using the amplifier.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 104 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
