- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
End of life for C7000?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Nigthawk C7000, which I bought in 2016, has fail intermittently for the last few months. Each time the cable company or I have to reboot it to get it going again. Also each time it goes down I never lose cable service, just the internet. Now when it fails, it default back to it old network id's, and I have to update them. Is my Nighthawk dying or is there a solution? Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: End of life for C7000?
Log into the cable connections page on it and take a screen snip of it. Post that back here with a screen snip of the logs.
that helps check your connection.
If you have any splitters, attenuators, or amplifiers in line, remove them. They can cause issues.
hard part about internet service is its more finicky than simple cable tv. Its need certain power levels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset been performed and setup from scratch?
Any Wifi Neighbors near by? If so, how many
