Orbi WiFi 7 RBE973
Reply
Firmware update for N600 Router
MarcinAus
I have been trying to apply a firmware upgrade for our N600 router. I've followed all the Netgear instructuctions but the main problem is the zip file downloaded from the website can't be opened - a message appears :"The disk image file is corrupted". Any thoughts - thx
Message 1 of 3
antinode
Guru
Re: Firmware update for N600 Router
> [...] our N600 router. [...]
   "N600" is a speed, not a model number.  Ever helpful, Netgear
product packaging emphasizes speeds like "Nxxx", but that's not the
model identifier.
> [...] the zip file downloaded from the website can't be opened - a
   When you do what, exactly?  On what kind of computer?
   What you should do is download the ".zip" archive, and extract the
files therein.  If you use Safari to do that download, then it may
automatically extract the contents of the ".zip" archive; with another
browser, you should be able to get contents extracted by double-clicking
on the downloaded ".zip" archive in a Finder window.
   Then, read the Release Notes file, which should include the
instructions for how to load the firmware into the router.  Hint:
Double-clicking on the ".img" file is not the way.
Message 2 of 3
MarcinAus
Many thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1277 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
