- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Help setting up small network with FS728TLP-V2 Switch with Telstra Gateway V7610
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Help setting up small network with FS728TLP-V2 Switch with Telstra Gateway V7610
> [...] when I connect the switch via WAN port on the modem to the
> switch (port 24- PoE disabled)'internet' drops out.
Is your Internet connection a DSL service, or something else?
(What?)
Try a LAN port instead of the WAN port? The WAN port is the wrong
side of the router for connecting multiple (or any of your) client
devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Antinode - Connection is DSL. So correct me if I am wrong ,this what I am planning to do,
* Give fix Ip to the Switch. (Same Ip range as per the modem) 10.192.168.xx
Do I need to create VLAN or not?
Use Modem / router IP as gateway?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
> 10.192.168.xx
Ok with me. I gather (from the Installation Guide) that the FS728TLP
can use DHCP to get its address (et al.) from the Gateway. I assume
that you can reserve an IP address for it on the Gateway rather than
configuring a static address on the switch, but it should work either
way. The important thing is not to try to use the DSL port and the WAN
port on the Gateway at the same time. The switch is part of your LAN;
the Internet is on the WAN side. And connecting something to the
Gateway WAN port would, I'd guess, disable the DSL modem in the Gateway.
Need? No. If all you want is a larger set of LAN ports, then just
connect the switch to one of the Gateway LAN ports. A simple unmanaged
switch could be used as well for that.
The Gateway LAN IP address, yes, but if you use DHCP, then the switch
should get that on its own (from the Gateway's DHCP server).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Antinode.. I will let you know the results.
