Reply
How to set up the plug-in USB drive for outside access via FTP and HTTP ?
MasterWin
I already registered and received the host name and IP address from MyNetGear/No-IP.  The DDNS status shows "succesfull" and I can ping the host name and the IP address from any computer.  I also set up the external FTP and HTTP access for the USB drive by checking the boxes.  But when I tried to access the host name or the IP address, it kept failing.  The error says "took too long to respond".  Is there some steps that I missed ?  Please help.
Message 1 of 5
DarrenM
NETGEAR Moderator
Re: How to set up the plug-in USB drive for outside access via FTP and HTTP ?
Hello MasterWin
What modem/router are you using?
DarrenM
Message 2 of 5
MasterWin
N300/C3000
Message 3 of 5
DarrenM
NETGEAR Moderator
Hello MasterWin
You may want to look at these articles make sure you have not missed any steps.
http://kb.netgear.com/app/answers/detail/a_id/23942/related/1?cid=wmt_netgear_organic
DarrenM
Message 4 of 5
MasterWin
I already went through that setup.  IThe USE drive is set up for external FTP and external HTTP using no-ip dynamic DNS IP address.  The issue I have is my Netgear N300 does not respond to the external FTP or external HTTP.  Is there some setting on N300 that I have to enable to make the N300 respond ?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2130 views
  • 0 kudos
  • 2 in conversation
Announcements
