- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Modem keeps rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought CM400 March 2015. Stoped working August 8th 2015. Have comcast as internet provider. They sent tech out to assess situation. Re-hooked up the CM400 directly to laptop and to wireless router. Summary of visit: CM400 modem just keeps rebooting every few minutes. Unable to keep internet connection. Swaped out CM400 with comcast modem and connection is fine. The coaxial cable port is a bit loose - could that be the problem? If so how do i go about getting the modem replaced as an $80 item should last more than 6 months.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Modem keeps rebooting
Hello PinPin
If you believe that the modem is defective I would contact Netgear phone support. They will be able to check with you and see if its defective and then replace it if it is still under warranty.
http://support.netgear.com/general/contact/default.aspx
DarrenM
User | Count |
15 | |
8 | |
8 | |
6 | |
2 |
