Orbi WiFi 7 RBE973
Reply
My C3700v2 runs 5ghz but not 2.4 ghz.
merncar
How can I get 2.4ghz not working on my C3700v2? 5ghz works fine.
Message 1 of 5
Guru
Re: My C3700v2 runs 5ghz but not 2.4 ghz.
Did it ever work?
What is the 2.4ghz led on the router showing?
did something change or were you changing anything?
Message 2 of 5
merncar
Thank you for your help! I dont think it has ever worked. I dont think I have changed anything. My devices that require 2.4 ghz have not worked since i bought this. The LED flashes on both the 2.4 and 5.
Message 3 of 5
Guru
if you log in through the browser, can you check to see if the 2.4ghz wireless was disabled? What does it show on the status page for wireless settings?
Message 4 of 5
merncar
When I attempt to login in says the password will beunencrypted. Nothing else happens, so i am unable to login.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 634 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
