Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
N600 docsis 3.0 wifi cable modem router static table size
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-13
08:44 AM
2015-06-13
08:44 AM
Seems to be this router does not allow to create static ip address out of the scope of DHCP, I decided to create a range of static IP addresses using fictitious mac address in the upper section of DHCP, actually does not allow to create more that 10 static ip address, getting message :
"Table is full. Remove an entry before adding new entry."
Is this correct?
Message 1 of 4
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-13
08:52 AM
2015-06-13
08:52 AM
Re: N600 docsis 3.0 wifi cable modem router static table size
Can you say which model of router you own please? N600 is a generic term.
There will be a limit on the number of Address Reservations that a router will allow, this can vary between models but is in the order of magnitude that you see i.e. 10 or 20 are typical limits.
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-13
09:27 AM
2015-06-13
09:27 AM
N600 WiFi Cable Modem Router
C3700-100NAS
I have never seen that kind of limitations, worse thing is that after reaching 10 static ip addresses and getting the message "table is full" if I delete and entry in the table and try to create a new one I am still getting the same message.
C3700-100NAS
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-14
10:08 AM
2015-06-14
10:08 AM
I believe the C3700 is an ISP provided router, Netgear can only change firmware with the agreement of the ISP, and the ISP decides on the feature set.
Message 4 of 4
Announcements
