Orbi WiFi 7 RBE973
Reply
N600 wifi router modem router
MartinaG
Ring is not enabled don't know how to connectRing is not enabled don't know how to connectRing device is not connected to network.Ring device is not connected to network.
Message 1 of 9
Re: N600 wifi router modem router
N600 is a wifi speed label, not a Netgear model number. There are dozens of N600 devices in Netgear's range.
What is ring and what are you asking?
Message 2 of 9
MartinaG
The model number is 802.11 n Dual Bamd gigabit. The ring is a doorbell that can take video but it must be connected wirelessly to the house wifi
Message 3 of 9
That is also a speed thing
Look for "Model Number" on the label on the back /bottom /side.
Message 4 of 9
MartinaG
Model no C3700
Message 5 of 9
antinode
Guru
> [...] The ring is a doorbell [...]
   Does it have a model number?  Does it come with instructions which
tell you how to connect it to your wireless network?
   This stuff isn't magic.  Some stranger can't walk up to your front
door with a Ring video/doorbell gizmo, and connect it to your wireless
network.  It must be configured, somehow.  Either you need to tell the
Ring gizmo which wireless network credentials to use, or else you need
to go through a WPS set-up procedure.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Do something similar
for the Ring gizmo.
Message 6 of 9
MartinaG
I DId follow lo the steps as indicated that is the reason why I posted in this blog for help. Thanks I will look for help someplace else
Message 7 of 9
antinode
Guru
> I DId follow lo the steps as indicated [...]
   I don't see the steps which you took.  All I see is:
      Ring-c08dbc
      Security-non-enabled
and a bunch of "Access Control" reports.  I don't know what
"Security-non-enabled" means, but my guess is this:
> [...]  Either you need to tell the
   I see no signs that you have done anything to let this Ring gizmo
join your wireless network.  Not blocking it with "Access Control" stuff
is not enough.
> [...] I will look for help someplace else
   No matter where you go, you may need to supply some useful
information, and/or answer some basic questions.
Message 8 of 9
OK. As long as you have the C3700 set up to broadcast its SSID, it is really down to the ring to make the connection.
If the ring supports WPS, then it may be a "press two buttons" thing.
There is a manual for the C3700 somewhere at the end of this link:
>>>> C3700 | Product | Support | NETGEAR <<<<
See page 53.
But that is just a guess. You will have to explain what you are doing. Or talk to the people who support the door bell. Perhaps there is a user group for that. Is this the device?
Ring's General FAQ - Frequently Asked Questions – Ring Help
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2172 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
