Orbi WiFi 7 RBE973
Reply
Need help with C7800 Disconnecting Often and lag spikes
Teelak
My C7800 is being used as a modem and router combo. Recently its been disconnecting often and manually restarting it would solve the issue for a couple hours. In addition there is huge amounts of lag when I try to game. I have tested multiple games yet the issue on my end. When I check the upstream and downstream(picture included), everything seems fine except for the uncorrectbles which I think is the cause for the packet loss.
I checked for splitters, and the coax cable. Everything is fine, I even switched out to the old modem/router and no problem existed. I hard reseted the C7800 twice, yet it did not solve the issue.
Can anyone please walk me through on how to solve this issue?
https://imgur.com/a/AfA3DM7
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: Need help with C7800 Disconnecting Often and lag spikes
Is the gaming device wireless or wired?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://highspeed.tips/docsis-events/
Check or PL using pingplotter.com with a wried PC and ALL other devices turned off or disconnected from the modem while testing.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 587 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
