Orbi WiFi 7 RBE973
Reply
Need help
Gtice
Follower
Need help
I have Time warner cable and want to change routers but the r7000 only has a wan connector and the router supplied by twc uses a cable connection,what do I need to do to use the r7000 instead of the twc router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Need help
Hello Gtice
you would have to buy your own modem like the cm400, cm500.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2338 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
