Orbi WiFi 7 RBE973
Reply
Netgear CM1000 compatibility
Chekekmpos91
Follower
Can someone please tell me if CM1000 is compatible with Eurodocsis and european isp?
I got that cablemodem when I was in the states but now I live in EU and I would like to set it up. My ISP uses eurodocsis 3.0 and my actual CM is the Arris TG2492
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 2
Guru
Re: Netgear CM1000 compatibility
Spec sheets doesn't mention EuroDocsis:
https://www.netgear.com/images//datasheet/networking/CableModems/CM1000.pdf
However I believe CM modems are compatibible.
I would check with your ISP first to see if they officially support the CM1000 on there system. They will know this.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 604 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
