- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Cable Modem router +\- mesh
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Cable Modem router +\- mesh
6000sq ft is rather sizable. What I'd do?
Buy a modem seperate from the router. You tend to have more control over updates, firmware, and settings.
Then you can buy whatever mesh system you prefer and add satellites as needed to the system to provide the coverage you desire.
I'd recommend the CM1000 or CM1100 for docsis 3.1 modems.
But something to check out? your signal quality from comcast. I'm not a fan of them but their modems tend to be fairly solid in terms of hardwired connection. If you're dropping both wired and wireless, it might be a signal issue and not a modem/router issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could try the CAX then add on a EAX8000 extender. It won't be a true mesh system however. Just a normal kind of wifi with an extender for wifi coverage.
I would recomend getting into a modem only option as mentioned by @plemans, then you can add on a NG orbi system if you want wifi MESH system. Like Orbi AX.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I were to buy this new modem/router. I have ethernet access to 2-3 other parts of the house. What about getting Wi-Fi 6 routers like the RAX 40 or 50 and setting them as access points. If I do that does that mean I have to disable the WiFi on the modem/router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you're needing multiple access points, I'd just go with a mesh system. Use the RAX devices as assess points would work but they aren't mesh so your roaming wouldn't be as seamless as going with a full mesh system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No but you would need to set different channels far apart on 2.4Ghz since AP mode configures it's own wifi signal and not extended or MESH which would use the same channel. So if you bought separate APs, then you would need to set channels on each to 1, 6 and 11. Same on 5Ghz, using far appart channels. This would not be an extended or mesh type network.
@Deval79 wrote:
Thanks for the info,
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it doesn’t workout I’ll go Mesh
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
