- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk CM1200 only getting 30 mbps hardwired.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk CM1200 only getting 30 mbps hardwired.
Do you have more than 1 device connected to the cm1200 or do you have a router using WAN aggregation?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only connect 1 device to the CM1200. Connect it to port 1. (google mesh doesn't support wan aggregation as far as I know).
Also, log into the router and click on the cable connections page. Get a screen snip of all the info and post it back here.
also do this for the modem logs. This helps us check the signal back to the ISP. A bad signal could cause issues.
You can also check with the isp to make sure they provisioned it right. I've had the wrong speed provisioning sent before or the wrong file (different device file)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk CM1200 only getting 250 mbps hardwired.
Firmware Version V2.02.05
No logs only getting 250 mbps on 600 mbps plan on Ethernet
Is there a starting frequency I should set for xfinity?
Apply Cancel
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 657000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
IP Provisioning Mode Honor MDD honorMdd(4)
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 37 657000000 Hz -1.3 dBmV 39.8 dB 0 0
2 Locked QAM256 9 483000000 Hz 0.2 dBmV 40.7 dB 0 0
3 Locked QAM256 10 489000000 Hz 0.3 dBmV 40.7 dB 0 0
4 Locked QAM256 11 495000000 Hz 0.4 dBmV 40.8 dB 0 0
5 Locked QAM256 12 507000000 Hz 0.4 dBmV 40.8 dB 0 0
6 Locked QAM256 13 513000000 Hz 0.3 dBmV 40.8 dB 0 0
7 Locked QAM256 14 519000000 Hz 0.1 dBmV 40.8 dB 0 0
8 Locked QAM256 15 525000000 Hz -0.1 dBmV 40.7 dB 0 0
9 Locked QAM256 16 531000000 Hz -0.2 dBmV 40.6 dB 0 0
10 Locked QAM256 17 537000000 Hz -0.3 dBmV 40.6 dB 0 0
11 Locked QAM256 18 543000000 Hz -0.4 dBmV 40.6 dB 0 0
12 Locked QAM256 19 549000000 Hz -0.6 dBmV 40.5 dB 0 0
13 Locked QAM256 20 555000000 Hz -0.7 dBmV 40.4 dB 0 0
14 Locked QAM256 21 561000000 Hz -0.6 dBmV 40.5 dB 0 0
15 Locked QAM256 22 567000000 Hz -0.8 dBmV 40.4 dB 0 0
16 Locked QAM256 23 573000000 Hz -0.9 dBmV 40.3 dB 0 0
17 Locked QAM256 24 579000000 Hz -0.7 dBmV 40.4 dB 0 0
18 Locked QAM256 25 585000000 Hz -0.7 dBmV 40.4 dB 0 0
19 Locked QAM256 26 591000000 Hz -0.7 dBmV 40.3 dB 0 0
20 Locked QAM256 27 597000000 Hz -0.7 dBmV 40.1 dB 0 0
21 Locked QAM256 28 603000000 Hz -0.8 dBmV 40.1 dB 0 0
22 Locked QAM256 29 609000000 Hz -0.9 dBmV 40.2 dB 0 0
23 Locked QAM256 30 615000000 Hz -1 dBmV 40.2 dB 0 0
24 Locked QAM256 31 621000000 Hz -1.2 dBmV 40.1 dB 0 0
25 Locked QAM256 32 627000000 Hz -1.2 dBmV 40.1 dB 0 0
26 Locked QAM256 33 633000000 Hz -1.3 dBmV 40 dB 0 0
27 Locked QAM256 34 639000000 Hz -1.4 dBmV 39.9 dB 0 0
28 Locked QAM256 35 645000000 Hz -1.6 dBmV 39.8 dB 0 0
29 Locked QAM256 36 651000000 Hz -1.4 dBmV 39.8 dB 0 0
30 Locked QAM256 38 663000000 Hz -1.2 dBmV 39.8 dB 0 0
31 Locked QAM256 39 669000000 Hz -1 dBmV 39.9 dB 0 0
32 Locked QAM256 40 675000000 Hz -0.9 dBmV 39.3 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 1 5120 Ksym/sec 16200000 Hz 41 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 22700000 Hz 41 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 41.5 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 35700000 Hz 41 dBmV
5 Locked ATDMA 5 1280 Ksym/sec 41200000 Hz 42 dBmV
6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
Downstream OFDM Channels
Channel Lock
Status Modulation /
Profile ID Channel
ID Frequency Power SNR /
MER Active Subcarrier
Number Range Unerrored
Codewords Correctable
Codewords Uncorrectable
Codewords
1 Locked 0 159 690000000 Hz -0.1 dBmV 40.6 dB 1246 ~ 2849 194048323 0 0
2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1 Not Locked 0 0 0 Hz 0 dBmV
Extended Upstream Transmit Power
Enable Extended Upstream Transmit Power
- Mark as New
- Bookmark
- Subscribe
- Permalink
Before you said you were only getting 30mbps.
Now you say your getting 200 mbps?
did you change something?
And the modem does have logs. https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
What device are you testing on?
have you tried a different device?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found the logs after I rebooted this morning. Xfinity did not open up all the ranges or something outside my house that is why I was getting 30 that is now switch to 200 but we tested with their hardware and they were getting 450-475 from their modem.
I was tested hard wired to my macbook pro.
Time Priority Description
Tue Aug 25 06:00:42 2020 Warning (5) Dynamic Range Window violation
Tue Aug 25 06:00:42 2020 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:40:68:80;CMTS-MAC=1c:e8:5d:f4:99:60;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 25 06:00:42 2020 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:40:68:80;CMTS-MAC=1c:e8:5d:f4:99:60;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 25 06:00:33 2020 Notice (6) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:40:68:80;CMTS-MAC=1c:e8:5d:f4:99:60;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:68:80;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Startup Procedure
1 Locked QAM256 37 657000000 Hz -1.1 dBmV 39.9 dB 0 0
2 Locked QAM256 9 483000000 Hz 0.3 dBmV 40.8 dB 0 0
3 Locked QAM256 10 489000000 Hz 0.5 dBmV 40.8 dB 0 0
4 Locked QAM256 11 495000000 Hz 0.6 dBmV 40.8 dB 0 0
5 Locked QAM256 12 507000000 Hz 0.7 dBmV 40.8 dB 0 0
6 Locked QAM256 13 513000000 Hz 0.6 dBmV 40.9 dB 0 0
7 Locked QAM256 14 519000000 Hz 0.4 dBmV 40.8 dB 0 0
8 Locked QAM256 15 525000000 Hz 0.3 dBmV 40.7 dB 0 0
9 Locked QAM256 16 531000000 Hz 0.1 dBmV 40.7 dB 0 0
10 Locked QAM256 17 537000000 Hz 0 dBmV 40.7 dB 0 0
11 Locked QAM256 18 543000000 Hz -0.1 dBmV 40.7 dB 0 0
12 Locked QAM256 19 549000000 Hz -0.3 dBmV 40.6 dB 0 0
13 Locked QAM256 20 555000000 Hz -0.4 dBmV 40.5 dB 0 0
14 Locked QAM256 21 561000000 Hz -0.4 dBmV 40.5 dB 0 0
15 Locked QAM256 22 567000000 Hz -0.5 dBmV 40.5 dB 0 0
16 Locked QAM256 23 573000000 Hz -0.6 dBmV 40.4 dB 0 0
17 Locked QAM256 24 579000000 Hz -0.3 dBmV 40.5 dB 0 0
18 Locked QAM256 25 585000000 Hz -0.4 dBmV 40.4 dB 0 0
19 Locked QAM256 26 591000000 Hz -0.3 dBmV 40.3 dB 0 0
20 Locked QAM256 27 597000000 Hz -0.3 dBmV 40.2 dB 0 0
21 Locked QAM256 28 603000000 Hz -0.3 dBmV 40.2 dB 0 0
22 Locked QAM256 29 609000000 Hz -0.6 dBmV 40.3 dB 0 0
23 Locked QAM256 30 615000000 Hz -0.6 dBmV 40.3 dB 0 0
24 Locked QAM256 31 621000000 Hz -0.7 dBmV 40.3 dB 0 0
25 Locked QAM256 32 627000000 Hz -0.8 dBmV 40.2 dB 0 0
26 Locked QAM256 33 633000000 Hz -0.9 dBmV 40.1 dB 0 0
27 Locked QAM256 34 639000000 Hz -1.1 dBmV 40 dB 0 0
28 Locked QAM256 35 645000000 Hz -1.3 dBmV 39.8 dB 0 0
29 Locked QAM256 36 651000000 Hz -1.1 dBmV 39.8 dB 0 0
30 Locked QAM256 38 663000000 Hz -1 dBmV 39.9 dB 0 0
31 Locked QAM256 39 669000000 Hz -0.8 dBmV 39.9 dB 0 0
32 Locked QAM256 40 675000000 Hz -0.8 dBmV 39.3 dB 0 0
2 Locked ATDMA 2 5120 Ksym/sec 22700000 Hz 40.5 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 41 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 35700000 Hz 40.5 dBmV
5 Locked ATDMA 5 1280 Ksym/sec 41200000 Hz 41.5 dBmV
Channel Lock
Status Modulation /
Profile ID Channel
Codewords
1 Locked 0 159 690000000 Hz 0.2 dBmV 40.5 dB 1246 ~ 2849 18580280 0 0
Current System Time:Tue Aug 25 06:09:52 2020
System Up Time:00:09:57
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, check with xfinity to make sure they properly provisioned it. When you say they "didn't open up all the ranges" its usually a tech says to cover for something else. Kind of like a mechanic saying your muffler belt was loose.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do those log erors mean? Dynamic Window Violation or Command Power Exceeded?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just like they sound. They tend to mean the power is fluctuating and exceeding their limits. Its common when you first connect/power on the modem but let it run for 24 hours and then pull the logs. If its happening throughout the day, then the isp needs to recheck the line.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How would I know if they provisioned my hardware correctly? I can't remember the termenoligy the tech said but he was on the outside of my house in their xfinity boxy making the changes. It was like it was not using all the channels but he said he opened them all. This modem is a 32 x 8 where their hardware is a 16 x 8.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Config Continued
- Mark as New
- Bookmark
- Subscribe
- Permalink
Config Continued
- Mark as New
- Bookmark
- Subscribe
- Permalink
All your current channels are locked.
And the logs take some time to run throughout the day to see if power spikes/drops.
They might have had a signal attenuator on the line or line block.
The provisioning is something they send to the cm1200 with the firmware when they set it up for usage. I've had them send the wrong provisioning file before that caused slow downs. Its why I'd recommend having them re-provision it.
I'd also recommend to make sure your testing directly connected to your pc and try this site: https://speedtest.xfinity.com/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok I will ask them later today. I am also direct connected with Ethernet port when I test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2 more logs came in
Tue Aug 25 06:12:48 2020 Warning (5)
DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:40:68:80;CMTS-MAC=1c:e8:5d:f4:99:60;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 25 06:12:47 2020 Critical (3)
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:40:68:80;CMTS-MAC=1c:e8:5d:f4:99:60;CM-QOS=1.1;CM-VER=3.1;
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reboot the modem I get the below errors. I get the same 4 errors.
Tue Aug 25 14:46:10 2020 Warning (5)
Tue Aug 25 14:46:01 2020 Notice (6)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Work with the ISP on getting the line and single working. Give this information to them. They need to make sure the line and signal up to the modes is working well. There is new FW for the CM1200 so be sure to ask your ISP about this. Have the ISP re-send the config file to the modem as well, then power OFF for 1 minute then back on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was the CM1200. I went to a CM700 as I only have a 600 mbps plan and now I am getting 670. All is good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
are you still seeing issues with CM1200 getting 600 Mbps?
please let us know.
30 Mbps sounds like your device is provisioned with default (wrong) config file.
Please re-activate and let us know.
give me the CM MAC as well.
