- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AC1900 C7000 ongoing router issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AC1900 C7000 ongoing router issues
Can you post your logs and the power levels of the modem may give a better idea of what is going on with the connection.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Lordlsafril
I see a lot of un correctables on your channels this may be a line issue or even the cable splitter is bad try removing the cable splitter if one is connected to the modem and go directly to the wall or try a different cable outlet if you are able. If this does not help you may want to have a cable tech come out and check the lines.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
They checked the lines recently. Apparently the lines in our walls are 59 line which Comcast stopped using 12 years ago. Somone will be out to fix them. Currently, only weird thing going on is my upstream light is blinking but my internet is fine.
