Reply
Nighthawk AC1900 R7000 - Moderate NAT Type
Werebeetus
Follower
I got this router because it was touted as a good gaming router, but ever since setting it up my NAT Type on Xbox One has been "moderate." How can I make it "Open"? I assume I should be able to given what I was led to believe about the router but I don't know where to start. There's also quitems a bit of lag.
The console is wired into the router.
Thanks!
Message 1 of 2
TheEther
Guru
Re: Nighthawk AC1900 R7000 - Moderate NAT Type
Your best bet is to turn UPnP on in the R7000.  You'll find it in ADVANCED > Advanced Setup > UPnP.  After you enable it, you'll probably want to reboot the router then the Xbox.  Then check the NAT state.
This troubleshooting guide may also be helpful.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4288 views
  • 0 kudos
  • 2 in conversation
Announcements
