- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AC3200 and Nighthawk AC1900:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been using my AC3200 with grate sucess. But, the signal strength in my familyroom is weak. As I have a bright house TV cable access avaialbe in the family room, I purchased the AC1900 Model C6900 Cable modem wifi router. I have yet to install or set up the AC1900.
I would like to know if these two wifi systems can be "joined" so to work together or do I just have to set the AC1900 up as a totally seperate wifi system? I read a support artical about "AP" access port mode - is this the direction I need to go?
If I am using the AC3200 as the main unit and WIFI system (with it's Netgear Genie set up and control), how do I set up the AC1900 as an Acess Point or in laymens terms, as a range extender? Does my current Netgear Genie software on the computer connected to the AC3200 reconize and or control the AC1900 once I plug the AC1900 in and connect it to the TV cable? Or, do I need to do the set up on the AC1900 with another (portable) computer (my lap top) to set up the AC1900? If so, then how do i get the Net Gear Genie software on my main computer to "see" and control the AC1900?
Thanks for any help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AC3200 and Nighthawk AC1900:
You didn't need to buy a router with a cable modem. Presumably, you already have a cable modem connected to your AC3200. A second cable modem doesn't serve any purpose and is a waste of money. You might want to return it for something without the cable modem. Get either a router or a range extender. Read on to decide which to get.
Yes, AP mode is preferred. It, however, requires a wired connection back to your AC3200. This can be, in order of best performance/reliability to worst, Ethernet, MoCA over coax or Powerline. If a wired connection is not possible, then you'll need a range extender instead of an AP.
By convention, an Access Point uses a wired connection back to the main router while a range extender is completely wireless. Somewhat confusingly, some range extenders have a setting that enable them to be used as Access Points.
Any router can be used as an Access Point. Some have a simple setting to enable it. Those that don't can still be set up as an Access Point with a little more work by disabling the DHCP server, setting an appropriate static IP address and connecting one of its LAN ports to the network (i.e. the WAN is unused). A range extender with support for Access Point mode will also have a simple setting to enable it. On a few models, the setting is controlled by a physical switch.
To set up a range extender, follow the instructions, which will walk you through the process of joining the extender to your existing Wi-Fi network. Most extenders will broadcast a new Wi-Fi network, but you may be able to change it to use the same name and password as you existing network to make things simpler.
I don't use the Netgear Genie software, so I can't tell you if it can manage more than one Netgear device.
