Orbi WiFi 7 RBE973
Reply
Nighthawk C7100V & APC BX1000M ups and an iMac
MikeBeacom
Hi-
I have a Nighthawk C7100V & APC BX1000M UPS on an iMac.
I've plugged the usb cable from the UPS to the modem, so the UPS can signal the computer to shut down during a power outage. I open "smb://readyshare", and see the flash drive plugged into one usb port, but not the UPS in the other port.
Is it possible to do this? Otherwise I'll have to get a 12 foot USB extention cable.
Thanks for your help,
Mike Beacom
Model: C7100V|Nighthawk AC1900 WiFi Cable Modem Router
Message 1 of 3
Accepted Solutions
Guru
Re: Nighthawk C7100V & APC BX1000M ups and an iMac
You posted this in the ReadyNAS forum area - it should have been posted here: https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
One of the mods will likely move it.
No, that won't work.  You'll need to connect the USB cable to the iMac.
The APC PowerChute software doesn't run on MacOS.  APC does provide some info on how to get the shutdown to work here: https://www.apc.com/us/en/faqs/FA159690/
Message 2 of 3
All Replies
Guru
Message 2 of 3
MikeBeacom
Thanks- I'll have to order that extention cable.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 563 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
