Orbi WiFi 7 RBE973
Reply
Nighthawk C7100V combo modem router
DonCook
Just purchased this unit and discovered it “needs” a battery. Does it need the battery to function? Or is the battery only used to work if the power to the house stops?
Message 1 of 4
Accepted Solutions
Kitsap
Master
Re: Nighthawk C7100V combo modem router
No, it does not need a battery to function.  The battery is only needed to function in the event of a power outage.
Both the Quick Start Guide and the User Manual indicate the battery is sold separately.
Message 4 of 4
All Replies
Guru
It did not come with a Battery? What does the user manual say about this?
Message 2 of 4
DonCook
This is what the operators manual says.  I read this to say the unit will run without the battery.  I will set up the unit and confirm that it does not need a battery to function.
Message 3 of 4
Kitsap
Master
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 761 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
