- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk C7800 automatic restart when no signal from cable
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I have a simple issue, I want to use my router as an AP since I moved to a new house and here I got fiber which is my only option. I was able to configure the router to work as an AP by disabling DHCP and assigning it an static IP that works within my network but there is a small issue.
The issue is that the router keeps restarting if there is no cable signal and by doing it does a full restart every 30s or so and it takes about 20s to get the Wi-Fi to reconnect.
Is there any way I can disable that automatic restart to be able to use it as an access point?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk C7800 automatic restart when no signal from cable
What FW is currently loaded?
I thought only the CAX line of modems had the auto reboot if no signal was detected...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Current Firmware is V6.01.07 and I was using XFinity comcast as the previous ISP
Also just in case for full clarification router model is NETGEAR Nighthawk X4S C7800 which is a modem/router combo unit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the clarification. I have one myself.
Wondering if NG put the auto reboot in newer code. Only thing I would try is to put a good quality coax splitter on the line and tap off it to the C7800 in faux AP mode which would probably stop the auto reboot. You don't have to do anything else. I know I had my C7800 in faux AP mode a while back as a test and saw no auto reboots, however it's FW hasn't been updated as I've not had it officially online for years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A coax terminator for the open input might do the job. The snip is from Amazon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would need to ensure that there is a good signal on the coax line input of the modem.
@wchardin25 wrote:
I have exact same issue. Any solution found?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any update on this?
@Omnoten wrote:
I will try with the terminator, the splitter didn't work so I might try the terminator and a combination, I will update with my results if it either works or it does not
