- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk cm1200 speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Be sure that LAG is disabled for testing speeds.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK752 (Router Mode), Wired Backhaul and R8500 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Nighthawk cm1200 speed
Is this a wired speed test with a wired PC connected directly to the back of the CM modem?
Is there a wifi router in between the CM modem and you wired test PC?
Max input would be 1G at the input or Coax line, however on the WAN Ports each WAN port could support up to 1Gb at each WAN port that can be assigned by the ISP for each port. So technically, you'll only need near 900mbps or up to 1000Mbps due to the connection rate on each WAN port is 1000Mpbs max.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
