Reply
No voice connectivity
georgewade
As  a result of recent heavy rains, our neighborhood went through a few days of service interupptions. When service (Xfinity) was restored, TV, internet and wi-fi were all back to normal. Bu the voice indicator on the modem is flickering and I have no voice connection. Was the modem somehow damaged, or does the issue lie with Xfinity?
Model: CM1150V|DOCSIS 3.1 Nighthawk® Multi-Gig Speed Cable Modem for XFINITY® Voice
Message 1 of 6
Accepted Solutions
Guru
Re: No voice connectivity
Ya, I would have them check the lines. Check your phone lines from the house to the phone box service area as well. Something may have got wet.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 6
All Replies
Guru
Message 2 of 6
georgewade
Thanks for the response...it was pretty much what I suspected. Thanks again...
Message 3 of 6
Guru
Let us know how it turns out.
Message 4 of 6
georgewade
Y'all nailed it! Comcast Tech found water in the outside receptacle on the side of the house, as well as a loose connection that must have occured during the install. Thank you all!
Message 5 of 6
Guru
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 210 views
  • 2 kudos
  • 2 in conversation
Announcements
