- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Possible hardware malfunction with cm1100
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would guess so. Modem seems non recoverable.
Will need to be replaced I guess.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Possible hardware malfunction with cm1100
Please post a copy and paste of the modems connection status page.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Can you access the modems web page at 192.168.100.1 with a wired PC and web browser with out the router connected?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
The CM modem is only a modem. Not a router here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's with nothing connected to the modem and no ISP coax connected?
Press the reset button in back for 10 seconds then release...
Might try a different power supply with same volts and amps if you can.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's correct, with only power connected I'm not getting anything. Tried a different power supply - same thing - only getting two bottom solid, amber LED's. Tried to a different ethernet cable - also no go. Is it possible for power spikes in the COAX line to have fried the electronics?
Edit: resetting physical power button does nothing either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
