Orbi WiFi 7 RBE973
Reply
Power source for CM600
smithbrasileiro
Follower
Hi, I am planning to buy a CM600 and connect it to a backup APC UPS battery which acts as a power source. But I need to know if the power input is compatible with this backup batter power pack.  My question is if the CM600 powersource input is the same as the R6700 Nighthawk cable modem, which I know is compatible with my battery pack. Does anyone know?
Thanks
Here's the APC backup, FYI:
https://www.amazon.com/gp/product/B079HFML55/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Model: CM600|CM600 High Speed Cable Modem
Message 1 of 3
Guru
Re: Power source for CM600
Check the power adapter sticker for input values. v110-120 is most common for North America Region.
Message 2 of 3
antinode
Guru
> [...] Does anyone know?
   People who've read the User Manuals for those devices might have a
clue.
   Visit http://netgear.com/support , put in the relevant model number,
and look for Documentation.  Get the User Manual.  Read.  Look for
"Technical Specifications" and, therein, the power adapter _output_
ratings.  Or look for the power ratings on the device itself.
      https://download.schneider-electric.com/files?p_Doc_Ref=SPD_CENZ-AVNMJ7_EN
   3.2A would seem to be enough for a device which needs 1.5A.  I can't
guarantee that the connector is the same, but I'd expect so.
> Check the power adapter sticker for input values. [...]
   Yet more evidence, if any were needed, that it can pay to read before
writing.  But thanks again for the useless "My Setup" data and the
animated icon.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 521 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
