Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Power yet no connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-20
05:11 AM
2022-07-20
05:11 AM
Nighthawk AC1900 WiFi Cable Modem Router
Cable is connected; Power Cord connected
Solid white constant light on top side reset button, and Tel 1 LED, Tel 2 LED, and Battery LED. All other LED lights are not on.
WiFi Not Connected when checking Settings on iPhone XR
Message 1 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-20
05:25 AM
2022-07-20
05:25 AM
Re: Power yet no connection
What AC1900 do you have (hint ac1900 is the speed, not the model)?
If its a modem/router combo device, have you tried unplugging the coax, then doing a reset on it? Push and hold reset for 7-15 seconds while its powerd on (with coax disconnected)?
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-20
05:57 AM
2022-07-20
05:57 AM
Thanks! It is a model C7100V
The top constant on button is the PUSH ‘N’ CONNECT—Easy push button WiFi connections (WPS)
I held that button for 10 secs with power plugged in and cable disconnected. No change. Try small recessed reset next?
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-20
06:12 AM
2022-07-20
06:12 AM
Yes the small recessed reset button is the one to push and hold.
The lights should change when held long enough. Then you'll need to go through the install procedure.
C7100V | Product | Support | NETGEAR
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-20
10:00 AM
2022-07-20
10:00 AM
Thanks. Pressed the reset button for 15 seconds with coax disconnected. Not the Power, DS/US, and Online buttons are faintly blinking. The 2.4 and 5 GHz buttons are faint and constant.
The top button is still on constant white light.
Will connect coax and attempt a reinstall.
The top
The top
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-20
10:56 AM
2022-07-20
10:56 AM
It’s been over 30 minutes, and the Power LED, DS/US, and Online LED lights are still faintly blinking. Nothing steady/constant as yet.
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-20
12:59 PM
2022-07-20
12:59 PM
have you checked to see if you grabbed the wrong power supply for device?
Message 7 of 7
Announcements
