Orbi WiFi 7 RBE973
Reply
Quality of Service settings do not save
iopredman
Initiate
Model: WNDR4500v2
Fireware: 1.0.0.72_1.0.45
OS: Windows 10 Pro Version 1909 Build 18363.592
Steps to repeat:
1. Log in to router.
2. Navigate to QoS setup via Advanced -> Setup -> QoS setup
3. Set uplink value at 9 Mbps
4. Check mark the box "Enable Upstream QoS"
5. Hit "Apply"
6. After the loading bar is finished, check box is
    unchecked and uplink value is blank
Note: I already have a QoS rule saved.
         This rule can be reached by clicking QoS rule.
          It does not reset unlike the checkbox.
Note: Router and modem have been reset.
Note: Portforwarding and Dyanamic DNS are enabled and being actively used.
Note: Computer is a wired connection
Any ideas or help would be appreciated!
Model: WNDR4500v2|N900 Wireless Dual Band Gigabit Router
Message 1 of 5
Guru
Re: Quality of Service settings do not save
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
Message 2 of 5
iopredman
Initiate
I have done so. Thanks! I'll close this when either gets a reply.
Message 3 of 5
Guru
Smiley Wink
Message 4 of 5
mintrieri
I may have the answer for you.
1. Go to the QoS settings
2. Edit the Device you want to change
3. ***Remove any spaces in the Device Name and Model Name
4. Hit Apply
My device and model name came up as "Playstation 4" by default with a space in the name. Changing them to "PS4" fixed my problem.
Hope that helps.
-mint
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 697 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
