- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
READYSHARE not recognizing USB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Out of nowhere, my external HD disappeared on the network. I couldn't find it on explorer, Genie, or Readyshare Vault. However, I could ping the address (192.168.0.5). I am on Windows 10, and using a Dell Laptop. I have been reading many suggestions but none seemed to work for me. I plugged the HD into my laptop and it was just fine. Any Ideas?
Genie is Version 2.4.50
My router is 3.01.14
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: READYSHARE not recognizing USB
addendum: I receive this message when I try to access 192.168.0.5 from explorer
The device or resource (192.168.0.5) is not set up to accept connections on port "The File and printer sharing (SMB)".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Were you able to fix the issue?
I just encountered the same this week.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased a uShare™ Mini NAS Adapter, and connected my USB HD to an ethernet port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the prompt response.
Ah, that means another power consumer and addt'l costs.
I imagine you did a good amount of digging.. should I find a solution, I'll be sure to let you know.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
