Reply
Router Compatibility with Crestview Cable
ldyork
Can anyone tell me if this cable/Wifi/voice router (C7100V-1AZNAS) works with Crestview Cable/voice?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 6
DarrenM
NETGEAR Moderator
Re: Router Compatibility with Crestview Cable
Hello idyork
You will have to check with the ISP but that only supports comcast at the moment.
DarrenM
Message 2 of 6
ldyork
Tried that three weeks ago and got no response.  Guess I'll have to get more aggressive.
Message 3 of 6
vkdelta
NETGEAR Employee
dont buy. it wont work.
this product is heavily customize to work with XFINITY/Comcast *ONLY*.
I suggest not to waste your time and money. on top of that, I suggest not to buy any other devices from retail unless your ISP says it is supported.
your best bet is to seperate voice and data using 2 different modems.
Message 4 of 6
ldyork
Thanks for the response.  My question exactly related to xfinity although Crestview did answer my call and said all gateways except Motorola and one I forget would work including Netgear.  The C7000B sounds like a great solution but not available for mere mortals only ISP's.
Message 5 of 6
ldyork
Just remembered.  The other one not recommended was Zoom.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 438 views
  • 0 kudos
  • 3 in conversation
Announcements
