Orbi WiFi 7 RBE973
Reply
Setting up a modem without an ethernet connection on a computer
i4abuy
Netgear's setup instructions call for connecting the modem to my computer with an ethernet cable.  My computer is MacBook Pro without an ethernet port.  How can I get around this?
Model: CM700|DOCSIS® 3.0 32x8
Message 1 of 5
antinode
Guru
Re: Setting up a modem without an ethernet connection on a computer
   The easy way might be to obtain (borrow, buy, rent, steal, ...) a
computer with an Ethernet port, or else get an Ethernet adapter for your
(unspecified) MacBook Pro.
Message 2 of 5
80njc80
Apprentice
I have set up plenty of times without one via wifi.  It does have its issues but can be managed if you know how.  I love that you follow the guidelines though!!!  At least someone reads before posting.
If you are keen on an ethernet cable you can source a wifi to ethernet adapter like antinode alluded too.
Message 3 of 5
antinode
Guru
> [...] a wifi to ethernet adapter like antinode alluded too.
   Actually, he was thinking of a USB- or Thunderbolt-to-Ethernet
adapter, like, say:
      https://www.apple.com/shop/product/MD463LL/A/
But with a description like "MacBook Pro", I have little idea which
ports are available on it for expansion.  (The last time I touched a
MacBook Pro (MacBookPro8,1, "Early 2011"?), it had an Ethernet port.)
Message 4 of 5
80njc80
Apprentice
Yup.  Typo.  I should proofread before posting...  Mind you, think of the possibilites!!!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 24590 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
