- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow Wireless / Fast Wired
- Mark as New
- Bookmark
- Subscribe
- Permalink
For my AC1600 (model C6250) speed test with ethernet cable is 120Mbps down, but with 2.4Ghz wireless from 5 feet away it is only 20Mbps. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow Wireless / Fast Wired
Hello cybernigel
Have you tried to adjust the wireless channel on the 2.4ghz?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi David,
I appreciate the reply. What specific adjustments to the 2.4Ghz channel are you suggesting?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
This Kb may help you with this just apply the same method it outlines to the 2.4ghz network.
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren,
I appreciate the reply and helpful KB article. I will try using a channel analyzer, but I did some brute force troubleshooting last night and tried each of the available 11 channels and ran speedtest.net against them. On the best channel I was still only getting ~30Mbps down while with a wired connection I'm well over 100Mbps down. I performed these tests about 5 feet away from the router and the R6250 does not have any adjustable attennas. Any other suggestions?
Thanks a lot
