Orbi WiFi 7 RBE973
Reply
T-Mobile Gateway kdv21 and Netgear c6300v2
ljones86
Follower
I used a coax to ethernet adapter to connect my Netgear Nighthawk to the T-moblile Gateway.  I wanted to use the Gateway as a modem and create a LAN via the Netgear NIghthawk.  How do I get the Nighthawk to broadcast internet.  The Nighthawk creates a LAN and I can connect my old printer and computer using this LAN but the LAN is not connected to the internet from the Gateway.  Anybody got a solution to get the Nighthawk LAN connected to the internet from the Gateway?
Message 1 of 2
Guru
Re: T-Mobile Gateway kdv21 and Netgear c6300v2
the coax to ethernet adapter won't work.
but you could try following this guide to try to make it an access point.
Can I use a C6300 cable modem without cable intern... - NETGEAR Communities
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 317 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
