- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Teamspeak random disconnects
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey! Teamspeak disconnects me at which seems random. This problem
started occuring when I upgraded the router. Before that I've had no
such problems at all. The router I currently use is R6220.
Error in teamspeak:
<20:29:04> Failed to connect to server <20:29:05> Trying to resolve hostname <20:29:07> Trying to connect to server
After I'm disconnected the client tries to autoreconnect but does not work
until I've restarted the client or switch back and forth from another server.
The only fix that I've seen regarding this problem which I've gathered
from other threads is to turn off DMZ, which I only tried for troubleshoot reasons.
So heres what I've done so far:
1. 'Disable Port Scan and Dos Protection'
Done, nothing changed in terms of the disconnect or anything noticable.
2. 'Disable SIP ALG'
3. Port Forward 'Teamspeak 3'
Teamspeak 3 Client uses the whole range of ports randomly so can't test this
4. Updated the router to the latest firmware (V1.1.0.86_1.0.1)
No changes at all, still having the same errors.
5. Client Log from Teamspeak.
2019-03-23 18:19:03 ClientUI Info Connect status: Connecting 2019-03-23 18:19:03 PktHandler Devel Puzzle solve time: 10 2019-03-23 18:19:03 ClientUI Info Connect status: Connected 2019-03-23 18:19:03 ClientUI Info Connect status: Establishing connection 2019-03-23 18:19:03 ClientUI Info Connect status: Connection established 2019-03-23 18:19:03 PermManager Info Loading permissions from cache 2019-03-23 18:23:57 Info tried to request user integration info without valid session 2019-03-23 18:33:59 Info Memory usage: 110.66 MiB 2019-03-23 18:48:59 Info Memory usage: 109.93 MiB 2019-03-23 19:03:59 Info Memory usage: 109.97 MiB 2019-03-23 19:18:59 Info Memory usage: 109.96 MiB 2019-03-23 19:27:40 PktHandler Info Dropping client 54 because of ping timeout 19 0 0 2019-03-23 19:27:40 SCHandler Warning Got command data while disconnected, dropping 2019-03-23 19:27:40 ClientUI Info Connect status: Disconnected 2019-03-23 19:27:40 ClientUI Info Connection lost, want autoreconnect = 1 2019-03-23 19:27:41 ClientUI Info Autoreconnecting 2019-03-23 19:27:41 ClientUI Info Connect to server: TEAMSPEAK_DOMAIN_NAME 2019-03-23 19:27:41 ClientUI Info Trying to resolve TEAMSPEAK_DOMAIN_NAME 2019-03-23 19:27:41 TSDNS Info A/AAAA DNS resolve successful, "TEAMSPEAK_DOMAIN_NAME" =(h: TEAMSPEAK_IP_ADDRESS p:0) 2019-03-23 19:27:41 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, "TEAMSPEAK_DOMAIN_NAME" =(h: TEAMSPEAK_IP_ADDRESS p:0) 2019-03-23 19:27:41 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, "gameservers.com" =(h: 108.61.13.173 p:0) 2019-03-23 19:27:41 TSDNS Info SRV DNS resolve unsuccessful, "_ts3._udp.TEAMSPEAK_DOMAIN_NAME" Domain name not found 2019-03-23 19:27:41 TSDNS Info SRV DNS resolve unsuccessful, "_tsdns._tcp.gameservers.com" DNS server returned answer with no data 2019-03-23 19:27:42 TSDNS Info TSDNS queried unsuccessfully TEAMSPEAK_IP_ADDRESS:41144 2019-03-23 19:27:42 TSDNS Info No TSDNS found 2019-03-23 19:27:42 TSDNS Info TSDNS queried unsuccessfully 108.61.13.173:41144 2019-03-23 19:27:42 TSDNS Info No TSDNS found 2019-03-23 19:27:42 ClientUI Info Lookup finished: ip=TEAMSPEAK_IP_ADDRESS port=9173 query=TEAMSPEAK_DOMAIN_NAME error=0 2019-03-23 19:27:42 ClientUI Info Resolve successful: TEAMSPEAK_IP_ADDRESS:9173 2019-03-23 19:27:42 ClientUI Info Initiating connection: TEAMSPEAK_IP_ADDRESS:9173 2019-03-23 19:27:42 ClientUI Info Connect status: Connecting 2019-03-23 19:27:47 ClientUI Info Connect status: Disconnected 2019-03-23 19:27:47 ClientUI Info Failed to connect to server, want autoreconnect = 1 2019-03-23 19:27:48 ClientUI Info Autoreconnecting 2019-03-23 19:27:48 ClientUI Info Connect to server: TEAMSPEAK_DOMAIN_NAME 2019-03-23 19:27:48 ClientUI Info Trying to resolve TEAMSPEAK_DOMAIN_NAME _______________________________________________ 2019-03-23 19:31:52 TSDNS Info A/AAAA DNS resolve successful, "TEAMSPEAK_DOMAIN_NAME" =(h: TEAMSPEAK_IP_ADDRESS p:0) 2019-03-23 19:31:52 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, "TEAMSPEAK_DOMAIN_NAME" =(h: TEAMSPEAK_IP_ADDRESS p:0) 2019-03-23 19:31:52 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, "gameservers.com" =(h: 108.61.13.173 p:0) 2019-03-23 19:31:52 TSDNS Info SRV DNS resolve unsuccessful, "_tsdns._tcp.gameservers.com" DNS server returned answer with no data 2019-03-23 19:31:52 TSDNS Info SRV DNS resolve unsuccessful, "_ts3._udp.TEAMSPEAK_DOMAIN_NAME" Domain name not found 2019-03-23 19:31:53 TSDNS Info TSDNS queried unsuccessfully TEAMSPEAK_IP_ADDRESS:41144 2019-03-23 19:31:53 TSDNS Info No TSDNS found 2019-03-23 19:31:54 TSDNS Info TSDNS queried unsuccessfully 108.61.13.173:41144 2019-03-23 19:31:54 TSDNS Info No TSDNS found 2019-03-23 19:31:54 ClientUI Info Lookup finished: ip=TEAMSPEAK_IP_ADDRESS port=9173 query=TEAMSPEAK_DOMAIN_NAME error=0 2019-03-23 19:31:54 ClientUI Info Resolve successful: TEAMSPEAK_IP_ADDRESS:9173 2019-03-23 19:31:54 ClientUI Info Initiating connection: TEAMSPEAK_IP_ADDRESS:9173 2019-03-23 19:31:54 ClientUI Info Connect status: Connecting 2019-03-23 19:31:59 ClientUI Info Connect status: Disconnected 2019-03-23 19:31:59 ClientUI Info Failed to connect to server, want autoreconnect = 1
6. Router Log.
[admin login] from source 192.168.1.19, Saturday, March 23,2019 19:32:16 [Time synchronized with NTP server time-g.netgear.com] Saturday, March 23,2019 19:27:53 [DoS attack: RST Scan] from source: 31.13.72.8:443, Saturday, March 23,2019 19:25:11 [DHCP IP: (192.168.1.5)] to MAC address F8:81:1A:51:88:97, Saturday, March 23,2019 19:18:06 [DoS attack: RST Scan] from source: 31.13.72.53:443, Saturday, March 23,2019 19:00:08 [DoS attack: RST Scan] from source: 31.13.72.36:443, Saturday, March 23,2019 18:59:20 [DHCP IP: (192.168.1.15)] to MAC address 00:17:88:AC:71:8C, Saturday, March 23,2019 18:47:58 [DHCP IP: (192.168.1.13)] to MAC address A0:C9:A0:D9:41:E7, Saturday, March 23,2019 18:45:19 [DoS attack: RST Scan] from source: 31.13.72.53:443, Saturday, March 23,2019 18:42:22 [DHCP IP: (192.168.1.12)] to MAC address 80:4E:81:AE:7D:B5, Saturday, March 23,2019 18:38:22
7. Turn off DMZ
Done and the error does not occur when running like this. But I won't be able to
run with DMZ off on the long run.
Any ideas for fixes regarding this error except for turning off DMZ and/or switching to OpenWRT?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Teamspeak random disconnects
Please post about this in this forum for your model router.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
