- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Turn the Nighthawk CAX80 into a Modem only
- Mark as New
- Bookmark
- Subscribe
- Permalink
CAX80 - Nighthawk® AX8/8-Stream WiFi 6 Cable Modem Router
How do I set it up the CAX80 as just a Modem? My House is just to big and I want to do a Mesh Wifi system and use the unit as Modem only (no Wi-fi and no router)
Thanks,
Rob
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.netgear.com/home/wifi/range-extenders/eax80/
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Turn the Nighthawk CAX80 into a Modem only
the CAX80 is a quite powerful router.
I'd actually leave it in router mode and put the mesh system in access point mode.
then just have the CAX80 use a different channel/ssid to prevent interference.
That'd allow you to have both a backup wifi network as well as offload a few devices from the mesh system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans Thanks for the suggestion.
So if I use an Orbi Mesh System I can set each unit into Access Point mode? I have used Orbi in the past and I do not remember that option.
Let me know if this is a question for a different forum.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks @Richard1864
Not sure how I missed seeing this item. I am very happy with the CAX80 and its Wi-Fi performance is very good as compared to what I have had in the past but it didn't do it with a 5,000 Sq Ft home, in some areas the signal was just week. Then add a couple gaming kids and you hear about it.
I will try this solution and since it is mesh I can always add 2 extenders if I need.
Rob
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now if I could just get my 19 month old kitten to stop eating Ethernet cables, it would be perfect.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
