Orbi WiFi 7 RBE973
Reply
USB Storage | Create Network Folder
JustAsIAm
I have a new C3700 router and it is working fine, except the following:
I select Advanced | USB Storage | Basic Settings and my 1TB hard drive shows up just fine, but when I go to "Advanced Settings" and select the radio button next to my hard drive, then select either "Edit" or "Create Network Folder", it goes back to the default "Advanced Settings" page.
Ideas?
Message 1 of 2
Fairytail
Virtuoso
Re: USB Storage | Create Network Folder
Make sure Pop-up blocker is disabled or pop-up is allowed. There should be a small window that will appear.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4266 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
