Reply
Highlighted
Voice calls cutting out
Voice calls keep cutting out intermittently....not a total drop...sometimes I hear just fragments of words coming from the other end.  Seems to get better after power cycle...but a couple of hours later same issue.  All wiring has been checked.  No noticeable internet interruptions.  Any ideas appreciated.  It's a pain when I'm making calls for work! model 7100V
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 12
Highlighted
NETGEAR Moderator
Re: Voice calls cutting out
Hello BZpbp
Have you checked with you ISP have them check everything on there side?
DarrenM
Message 2 of 12
Highlighted
Yes...all checked out....in fact, they installed a voice only modem, and there were no issues.  When I went back to 7100V...calls cut out.  there must be a conflict somewhere interfering with voice calls
Message 3 of 12
Highlighted
NETGEAR Moderator
We want to work with you on this send me a PM with your name, email, and phone number and our support team will contact you.
Thanks
DarrenM
Message 4 of 12
Highlighted
I have the same problem with my c7100v. Very frustrating. Comcast says everything looks fine.
Message 5 of 12
Highlighted
Yes....same thing here...I have now given up on using the 7100v for voice...comcast installed a separate voice modem, and I haven't had a problem since.  There is some issue with the 7100v voice setup....I don't have the time to figure it out.
Message 6 of 12
Highlighted
Exact same problem here - Comcast says signals look fine on their end but we have a terrible issue of voice dropping in/out during calls.  Makes it essentially unusuable.
Like other poster - Power cycle does make it better for a while
Message 7 of 12
Highlighted
Voice has worked perfectly since disabling WiFi a few months ago. I'm using my old R7000 for WiFi, which was a better piece of hardware anyway. Pretty disappointing that a not-inexpensive router doesn't work as advertised. Netgear doesn't seem interested in fixing it and I'm probably done with them.
Message 8 of 12
Highlighted
Agreed...this was not an inexpensive piece of equipment.  You have nto had a problem since disabling wifi...and I have't had a problem since installing separate, voice only modem.  Obviously a conflict between wireless and voice, which Netgear has no interest in solving
Message 9 of 12
Highlighted
I have the C7100V AC1900 Cable Modem Voice Router. The voice calls started cutting out about two weeks ago. There are no issues with Comcast -- just the voice so I need help in getting this issue resolved!!!!
My modem/router wasn't a selection in the dropdown -- the NightHawk is the latest version showing. Hoping that I'm not told this VERY EXPENSIVE router/modem is no longer supported.
Can someone tell me where I can get the software patch to correct this VERY FRUSTRATING issue?
Thanks!
Billie
Message 10 of 12
Highlighted
Hey there.....sorry to say...but join the club.  The 7100v should never have been approved by Comcast, because it is incapable of delivering a quality voice sgnal.  However, there is supposedly a firmware update that fixes the issue coming out soon.  If we're lucky, it will fix the problem....I'm not betting on it though.
Message 11 of 12
Highlighted
Well that stinks! I purchased my router/modem in October and the phone/voice was working fine until a couple of weeks ago. Any other place/forum we can pass along our angst?
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1383 views
  • 0 kudos
  • 5 in conversation
Announcements
