Orbi WiFi 7 RBE973
Reply
WIFI just died -Nighthawk C7000v2
Torgod13
Was online and suddenly was disconnected.  Rebooted the router/modem. Came back online, but no wifi. Light is on, 2.4 and 5 is lit.
All hard wired systems connect just fine.  Can not log into the router.  It says there is not wifi and to turn it on, then loads the netgear website.   Is this because of the issues Netgear is having or is it on my side?
Thanks in advance....
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 3
Guru
Re: WIFI just died -Nighthawk C7000v2
did the wifi on/off button get hit? push and hold it for 2 seconds
Message 2 of 3
Torgod13
Thanks, but i started with that.  I fillanly had to do a factory reset to fix the problem.  Still dont know why or how it happened.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 605 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
