Reply
Wired Ethernet Speed Is Faster On Modem Than Router.
internetishard
so i got xfinity gigabit a few days ago and i just bought a new modem and i also had an exsisting netgear orbi. When they hooked it up. i did a speedtest on my modem and i was getting 940-1000+ mbps. But when i used the orbi ethernet ports i only got 300-800mbps. Why?????????????????
Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem—DOCSIS 3.1, RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Wired Ethernet Speed Is Faster On Modem Than Router.
Please post here for your model Orbi:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
As this will be an issue at the Orbi, and not the modem.
Thank you.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 4
internetishard
I use a netgear cm1100 cable modem (1 gigabit docsis 3.1) which is allowing the netgear orbi rbr20 and rbs20 (using wired backhaul between sattelite and water.) The orbi router is the RBR20. Then I am connected through an ethernet cable to my computer and still only get 200-800mbps. While downloading fortnite, it only uses 200mbps.
My laptop (macbook air 2015 with amazonbasics usb to ethernet 10/100/1000) only gets 200mbps.
Message 3 of 4
Guru
Thank you.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 909 views
  • 0 kudos
  • 2 in conversation
Announcements
