Orbi WiFi 7 RBE973
Reply
XFinity says I am not getting speed because of my router
smbaligh
Not getting enough speed, I have a 100Mbps connection and I only get 25-30Mbps, Although this is Xifnity certified router but based on my call with XFinity earlier today, Net Gear routers are not good, Since I haven't bought it from them I should get one from them.
My question is why does Net Gear sell these bad routers?
Model: C3000|N300 Cable Gateway Docsis 3.0
Message 1 of 4
Guru
Re: XFinity says I am not getting speed because of my router
Are you testing wireless or wired into the router?
What device are you using for testing?
Do you have a screen snip of the cable connections page and the modem event logs?
Message 2 of 4
smbaligh
I am testing it on wireless (WiFi)
Testing speed on my MacBook Pro
I am not sure how can I get it, Can you share any link I can follow to get the logs?
Message 3 of 4
Guru
Test it wired.
The C3000 isn't dual band. And 2.4ghz is a slow network and its sensitive to inteference.
Its the reason for dual band routers. In this day, I don't recommend single band routers unless you live in the country with no one around and you're using dialup/dsl.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 613 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
