- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xfinity disables 2.4Ghz on CAX30
- Mark as New
- Bookmark
- Subscribe
- Permalink
My CAX30 will broadcast on 2.4GHz and 5GHz up until the moment I activate it with Comcast Xfinity, at which point I only have access to the 5GHz band. Admin controls say it is still working but none of my devices see it. I've been through all the resets, firmware updates and backdates, channel changes, etc. that have been posted and suggested by Netgear support. Comcast clearly doesn't want me using my 2.4GHz only devices including my smoke alarm.
Does anyone have any theories regarding a work around? (Unfortunately, leaving Comcast is not an option in my area). Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xfinity disables 2.4Ghz on CAX30
are you using smart connect?
Have you done a wireless scan using something other than windows?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am not using smart connect. And I haven't done a wireless scan using something other than windows on the computers (I'm afraind I don't know how), but the android devices, the printer, and the smoke alarm don't see it either.
Thanks for thinking about it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try doing a scan using inssider or any of the general wifi scanners that can be downloaded. there's quite a few of them. I use inssider or winfi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for this. With Winfi Lite, I do see the 2.4 GHz band is present. Though, I'm not sure how to apply this good news to getting my printer and smoke alarm to see it now the we know that it is actually there.
Do they have a Winfi equilivalent for old HP printers and Nest smoke alarms? (she asks optimistically)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is you ssid broadcast disabled in the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, both bands are broadcasting. When I disable broadcasting the 5Ghz, it shuts off just as expected and I have to go dig out the ethernet cable, but not suprisingly, has no effect on the other band. Toggling the 2.4 GHz SSID broadcast has no effect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having similar issue. The 2.4 shows option to connect but most 2.4 devices are unable to comunicate with the router/modem. I have suddenlink as provider.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I've ended up doing as a temporary solution is activating an old 2.4Ghz only Netgear C3000 modem/router with xfinity (despite all their warnings not to) and setting up the network as I want the new 2.4GHz network to look. I connected all my older devices to this network and while leaving the router portion running transfered the service to the CAX30. Then I set up the 5 GHz band and made sure everything there was working before changing the 2.4GHZ band on the CAX30 to match the C3000. This made everything angry but when I shutdown the C3000 all the devices jumped to the CAX30.
Of course doing this meant I that I couldn't properly activate the CAX30 through Xfinity and I had to call them in order for them to do it manually.
It may work in a pinch, but this is an unreasonable process for every power outage. On top of having Xfinity I also have PG&E.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd make contact with NG support on this and let them know what your experiencing...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have. The person I spoke to went through the basics, then refered me to higher ups who would call "soon". That was a few days ago. I'm not sure what kind of "soon" to expect, so I thought I check with you very smart folks to see if anyone had any ideas.
I appreciate the help getting it limping along.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would keep in touch with support. You'll need to use that 2ndary wifi AP for now until this is resolved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I'll update with a solution is we get to one. I appreciate everyone's effort.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
