Orbi WiFi 7 RBE973
Reply
ac1200 how do i stop others from using my router
owlette2
the fa mily downstairs are using my service,how can i block them?
Message 1 of 5
Guru
Re: ac1200 how do i stop others from using my router
Which model NG router do you have? AC1200 isn't a model#.
Message 2 of 5
owlette2
AC1220
Message 3 of 5
Guru
AC1200 and AC1220 aren't models.
But your simplest route to keep others from using your router would be to change your wifi password and not to give them access to plugging a device into it.
go to netgear.com/support/   and type in your actual model. Then you'll have access to the manual that walks you through changing passwords.
Message 4 of 5
Guru
Well is it a R#### or C#### or something like this? This would be a model number we are looking for.
@owlette2 wrote:
AC1220
Message 5 of 5
Discussion stats
  • 4 replies
  • 632 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
