Orbi WiFi 7 RBE973
Reply
anyone know how to configure cm1150v modem for port aggragation? user guide says it will do it
BRogers
Follower
Message 1 of 6
vkdelta
NETGEAR Expert
Re: anyone know how to configure cm1150v modem for port aggragation? user guide says it will do it
There is LAG config option in the Modem Page.
Message 2 of 6
Guru
If the option isn't there,for a while, internet providers weren't enabling the option with the cm1150v unless you had a certain plan.  It required updated firmware. Not sure of this status as its been a couple months since this was an issue. Might be something to check into with your provider if you can't find the option in the modem page.
@vkdelta would know more about this then I would.
Message 3 of 6
vkdelta
NETGEAR Expert
What is the FW on the device?
LAG needs a FW upgrade which was recently pushed out by Comcast.
Message 4 of 6
tgltgl
Star
Can port aggregation on cm1150v be used to connect to Orbi RBK50?
Message 5 of 6
Guru
Orbi doesn't have link aggregation. If you have other questions, please start a dedicated thread for you specific questions or search the forums. Your questions might have been answered.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1189 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
