- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
c3700-can't conect
- Mark as New
- Bookmark
- Subscribe
- Permalink
c3700-can't conect
I bouth a c3700 back in December. It was working fine for the most part until last Monday. At that point, while it says I have a connection, I can not connect to any pages. It does not matter if I try to connect wireless or by ethernet cable. Moreover, I have tried to reboot and set to factor defaults, but it did not work it. I called Time Warner and they sent out a tech. He told me that the internet was fine, but the modem was not passing it through. Does anyone have any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: c3700-can't conect
Actually, I can connect to the internet on the guest network, but not through the ethernet cable or the other networks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Seanmccat
If you tried factory resets and still cant connect it may be a hardware malfunction I would suggest contacting netgear support to check. If its still under warranty possible to get a RMA if its not working properly.
DarrenM
