- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cabletester GS305E reports faults on new cables
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear cable tester reported some faults in my existing CAT5-cables, so I decided to replace the lot with new CAT6-cables (eventhough the existing cables seemed to be working fine). And, would you believe it; I just connected one side of 2 brandnew 15-metre cables, and the cable tester reported a fault at 13 metres! I then switched the cables around, and connected the other side of them - SAME result!! Here also, it reported a fault for BOTH cables at 13 metres.
The new cables are branded as S/FTP (PiMF) LSZH, CU.
From what I read about it, such cables would be fine, up to 50 metres, or even 100 metres.
So, what's up with that?
Should I take Netgear Cable Tester with a pound of salt?
Is it just too picky?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cabletester GS305E reports faults on new cables
Please post about this in the Switch forum.
Good Luck.
@LexNoyb wrote:Netgear cable tester reported some faults in my existing CAT5-cables, so I decided to replace the lot with new CAT6-cables (eventhough the existing cables seemed to be working fine). And, would you believe it; I just connected one side of 2 brandnew 15-metre cables, and the cable tester reported a fault at 13 metres! I then switched the cables around, and connected the other side of them - SAME result!! Here also, it reported a fault for BOTH cables at 13 metres.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I noticed the Switch option before I signed on; after that, under Home Network it never showed again, so that routers/modems seemed the best (and only) choice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for that info; I have posted my question there. So consider this issue closed.
I just hope my Switch isn't going to be as quirky as the website :).
- Mark as New
- Bookmark
- Subscribe
- Permalink
