Orbi WiFi 7 RBE973
Reply
cax80
q162528q
Follower
cax80
router not working tried tech support for hours..obviosly in some sort of boot loop or something-defective all over the web that these are notorious-need replacement
Message 1 of 4
Re: cax80
Nothing like enough, if any, detail in there that anyone can use to diagnose what might be happening.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 2 of 4
Guru
Re: cax80
Message 3 of 4
Guru
Re: cax80
https://community.netgear.com/t5/Cable-Modems-Routers/NOTICE-Users-with-sudden-non-functioning-CAX80...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 491 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
