- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
monitoring internet bandwidth usage
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having some issues with monitoring which device is using how much bandidth. It seems that D-Link and Asus routers can have dd-wrt installed and this OS gives a great breakdown of what is happening. Is there anything I can do with Netgear OR do we need to get a new router?. I have glasswire installed on the windows machines but I also have macs and iphones and ipads and putting it all together is a hassle. I cant beleive that Netgear does not have this basic mechanisn. Their genie app just gives one number and no device OR no app thats driving usage and makes it almost useless..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: monitoring internet bandwidth usage
dd-wrt is a third party firmware.
Some netgear routers do have the capability of running it but you didn't put what you have for a router.
Also, if you look, not all asus or d-link routers support dd-wrt. Kind of like Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: monitoring internet bandwidth usage c7000v2
Thanks much for the reply. I had entered the model number in the "model" field that the netgear message submission recommended :-(. It is doing something non obvious with that info and I have not appended the mode # c7000v2 to the subject to help. Appreciate any pointers
- Mark as New
- Bookmark
- Subscribe
- Permalink
the C7000v2 is a modem/router combo device.
D-link, Asus, Netgear, etc all aren't able to have user directed firmware with their devices that have an integrated modem. its controlled by the ISP. so you can't install 3rd party firmware to them.
To do something like that you need a modem and router seperate.
sorry.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see. so the best option is to just get a wifi router and physically hook it up to the c7000v2...That way I can have the monitoring firmware on the wifi router which talks with the modem (c7000).
- Mark as New
- Bookmark
- Subscribe
- Permalink
The C7000 has modem only mode. You can connect a router to it with data monitoring. Just make sure your C7000 is in that modem only mode or you'll be running a double nat
