Orbi WiFi 7 RBE973
Reply
n300 model c3000 no wireless connection but workes using cable
inkredible
Follower
Hi!
after a storm hit i unplugged my n300 (c3000) router just to be safe. then when turning on again it stopped providing internet connection wirelessly but it works perfictly fine when connecting it using the eathernet cable. not sure if this becuase of the storm since it works using the cable. all lights are turned on exept for the first and last one.
Do i need to buy a new one or is there another solution.
thank you
Model: PR2000|NETGEAR Trek - N300 Travel Router and Range Extender
Message 1 of 2
Retired_Member
Not applicable
Re: n300 model c3000 no wireless connection but workes using cable
Read page 101
http://www.downloads.netgear.com/files/GDC/C3000/C3000_UM_21Aug2014.pdf
If after reading and after a factory reset........same problem exists replace or contact support if under warranty
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1781 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
