- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
no voltage on POE port
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
I'm looking for some help and advice on working out how to use my Prosafe GS10TP I purchased it to run 3 unfi Wi-Fi discs they require PoE.
I cannot get the system to power the devices. I know the discs work because I have a single, stand-alone POE and if I connect it after going through the prosafe the disc works fine.
Thank you
Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: no voltage on POE port
> [...] my Prosafe GS10TP [...]
GS110TP? Not really a "Home Networking > Cable Modems & Routers"
topic, is it?
> [...] unfi Wi-Fi discs [...]
UniFi? Model? Power requirements? And then, what can the
GS110TP(?) provide?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You tell me what should it come under?
That was the only categories on the drop-down list
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are we talking about a GS10TP or a GS110TP?
Which "the drop-down list" was that?
Knowing nothing, other than that it's not a router, I put "GS110TP"
into the first "Search the Community..." box I found (at:
https://community.netgear.com/t5/NETGEAR-Forum/ct-p/en-netgear), and was
led to places like:
https://community.netgear.com/t5/Managed-Switches/bd-p/business-managed-switches
How was this determined? Did you measure the voltage?
> I cannot get the system to power the devices. [...]
"I cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it.
From my brief reading, I gather that PoE is subject to control by the
device administrator. The "Smart Switch Software Administration Manual"
has a section on "PoE Configuration", for example.
Start at http://netgear.com/support/ , put in your model number,
select Documentation, download the manual(s) of interest, and peruse?
> GS110TP(?) provide?
Still wondering.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your patience and understanding.
What I am trying to do is add, a wireless network to my office, workshop and stores. I purchased unifi long-range Wi-Fi discs (picture enclosed) as they require PoE, I was recommended the netgear prosafe GS510TP (picture enclosed). I have a cable from my modem into port one. What feeds Internet to the other ports, but I am unable to get the PoE to work for the devices.
I hope that's a bit more clear . Thanks again for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] Wi-Fi discs (picture enclosed) [...]
It would be more efficient to provide a simple model number than a
picture of anything.
> [...] netgear prosafe GS510TP (picture enclosed).
Picure not required, only some accurate model information. What
happened to the GS10TP or GS110TP?
What "my modem" is might be interesting. "port one" of what? The
(uncertain-model) switch?
> > GS110TP(?) provide?
> Still wondering.
It shouldn't be this difficult to get an accurate hardware inventory.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't worry about it mate, sarcasm is something I don't like or appreciate.
I have boxed the piece of **bleep** up and he's going back I remember back in the 80s this stuff was a piece of **bleep** anyway!!
I rest my case with anyone classing themselves as a expert...
Get a life get out more mate...
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] sarcasm is something I don't like or appreciate.
And, apparently, don't recognize. Where was it?
> [...] anyone classing themselves as a expert...
I don't see that either. Are you reading the right thread?
> Don't worry about it mate, [...]
Done. I wish you the best of luck with your future attempts to get
useful information without supplying any.
