- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
router for cox gigablast
- Mark as New
- Bookmark
- Subscribe
- Permalink
my modem is arris sb8200
which router works well with cox gigblast?
looking for a basic, easy to setup router, that is not slow and works well with cox gigblast speed
tried my linksys ea6500 router but it was super slow for gigablast
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: router for cox gigablast
If your asking about NG routers, R7800 series or higher. R8000/9000 should support near 900Mbps on the WAN to LAN. NGs XR450/500 as well. I know my XR450 gets 900Mbps on the WAN to LAN side. I tested the XR700 and the one I had failed the WAN to LAN test. Hopefully FW will fix that.
Please post about this also in the Nighthawk router forum:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
