- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
wired readyshare
- Mark as New
- Bookmark
- Subscribe
- Permalink
wired readyshare
Can't turn off readyshare on my Nighthawk AC1900 WIFI Cable Modem Router
The network map shows there is a wired computer as readyshare connected to the router. I just let my own devices to connect to the internet and no other device is allowed but it seems this wired readyshare is allowed. I cannot find anything in the router settings to disable readyshare and can't uncheck the "basic" mode. Any ideas on how to resolve this issue????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wired readyshare
Can you post a screen capture of this Readyshare page on the modem?
Try a factory reset and setup from scratch with a wired PC and web browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the screenshot from the attached devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There were many other posts (for example: "Unknown device connected to wifi" from 2018; "N600 Model C3700 ReadyShare - Does is show on my network as a linex computer? from 2018; " C3700-100NAS ReadyShare - Disable This Feature" from 2020) related to this issue. Apparently there is no a clear solution suggested.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are there any options on the ReadyShare page on the modem that you can select or this just shows whats connected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only shows "Basic" chosen.
I also tried the suggestion given in the post (C3700-100NAS ReadyShare - Disable This Feature" from 2020). Initially it disappeared from the list but then it came back after some time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
