× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
4g Antenna for LB2120 4g modem
G11ARY
Initiate
Looking for advise on best antennas to boost my signal strength as I’m in the middle of a week spot please
Model: LB2120|4G LTE Modem
Message 1 of 3
Blanca_O
NETGEAR Moderator
Re: 4g Antenna for LB2120 4g modem
Hi @G11ARY
Welcome to NETGEAR Community!
You may want to check this link :
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Antenna-connection-for-LB2120/m-p/17...
KB reference link:
https://kb.netgear.com/23901/External-Antennas-for-AirCard-products
Blanca
Community Team
Message 2 of 3
psynpase
I have consulted the knowledge base article on external antenna (and have left a message there).  The article makes clear that Netgear will not be responsible for external antenna connected .... (which is reasonable)  but it does not give details of suitable antenna types.
So my question to the community?  I have recently bought a LB2120 , I am using it in a rural setting and in order to get a strong enough signal I will need to connect 2 external directional antenna.  I am proposing to use antenna with a folded dipole active element (plus balun).  These will present a 50 ohm impedence to the modem but a short at DC.  Will the modem accept this, as did the Huawei that I used before buying the 2120.
(I have not tried the telephone helpline because I suspect that the question is too technical and specific)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2904 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
